T554 tym
/ T554 tym #1
ihuntbear
new brunswick, canada
2015 tym T554 and 1999 Kobota m4700
Hi All...
Just bought a new T554 TYM with 0 hrs ...What a great little tractor.I've put 35 hrs on it in the last two weeks so i called the dealer for her fifty hour lube change.The dealer told me filters were 275.00 for 4 filters plus oil and hyd fluid..I said the filters must have gold linings in them.Any of you people have cross reference numbers that aren't as pricey? Two of the filters are yamnar and the other two are tym..All spin on....Fuel filter being the most expensive 74.95...
fuel filter yamnar 129A00-55800
oil flter yamnar 129150-35153
hyd filter TYM 15532302100
hyd filter TYM 17975152101
any help would be greatly appreciated...thks again for all the good reading here
/ T554 tym #2
Congrats on the new tractor. Any likes or dislikes about it. Does the exhaust have a slight chlorine odor like diesel cars and trucks. I would take the filter numbers to NAPA and see if they ca cross reference them.
/ T554 tym
No smell at all...like the tractor...only problem I had was blew up the battery and alternator first day
..they put extra work lights on and the alt wouldn't take it.. The alt that it came with was 55 amp and wouldn't keep up..they put a 105 amp one on and new battery and it works perfect...lots of power
/ T554 tym
I called everywhere here..i guess they are all dealer items....that kind of sucks
/ T554 tym #5
Hi All...
I do just purchase one myself. And I just did my own 50 hrs service. My is an hst model
and if I am not mistaken you do also need to replace the water seperator as well to honor
the warranty . Luckily my dealer gave me the hydraulic filter when they deliver my tractor
so I only need to order the oil, fuel, hst, and water seperator filter. Cost me $200.00 including
shipping.
/ T554 tym
Hi All...
found out 1291-50-35153 crosses to 1334mp---$13.09 there is an other number that it crosses to but lost it that was a fleetguard number for $4.05
1553-23-02100 crosses to p550162.
/ T554 tym #7
I would not use after market hydraulic or transmission filter
cuz the bypass being smaller then the oem. That will effect
the flow rate. For oil and fuel filter its ok to use after market.
you only doing filter change in the 500 hrs interval. So its not
much money saving . Its may void your 5 years warranty. Its
just my 2 cent.
/ T554 tym
What's funny about that is the dealer uses after market filters but crosses off the number and puts his over it
/ T554 tym
Everything crosses but the fuel filter..go figure it's the most expensive one
/ T554 tym #10
Some thing fishy about your dealer there. My dealer process my order but
was shipped directly from the distribution center in NC.
/ T554 tym
U mean your dealer doesn't have any stock...I wouldn't want your dealer if I have to order and wait for my parts..I blow snow for a living and don't need down time. ..time is money for me
/ T554 tym #12
Your dealer sounds like a scam artist when he takes aftermarket filters, crosses off the numbers and puts his numbers on them. Why use him?
/ T554 tym #14
Most dealers in the us have parts drop shipped from the warehouse here in NC. It still takes me a week to get parts and I am 30 miles from the TYM warehouse. And no, they will not let me go pick up the parts that I need so I order them through Smiths.
/ T554 tym
Well he is my dealer that provides my warranty and has parts on hand rather then waiting 4 days for parts...that's not good service...by using after market filters doesn't mean they don't work..wicks.fleetguard hastings fram all make good filters..I don't thing tym has their own filter plant..somebody makes them for them and puts tym numbers on them...just my 2 cents
/ T554 tym
somebody said they wouldn't use after market filter because the bypass is to small..well my 2 cents is if it happens to go into bypass the filter should have been changed long before it did...i talked to a filter rep he told me when they cross a filter to there's it has to be an exact match,microns ,gasket dimention,thread pitch for spin on,size of filter...he also said they make them for various tractor plants and put there name and numbers on it( example Deer,new holland )he didnt know who makes tym,he didnt think tym had its own filter plant...i change my filters and fluids every fall whether they need it or not..i always wipe my quick connects with a rag changing implements.my tractor has 5 filters on it 3 tym and 2 yanmar..most expensive the fuel filter yanmar 74.94 plus tax...hopefully i dont have to change that to many times for gelling or water..but i add lucas fuel additive with every fuel fillup with no problems......just my 2 cents
/ T554 tym #17
After your first 50 hours then every 500 hours after that. So most average user
put about 100 hours yearly. 5 years to change the filters. I can deal with that.
/ T554 tym
wow..i see u didnt read the manual..mine says everything first 50 hours.after that oil filter and fuel filter every 200 hours ,air filter clean every 200 hrs....trans hyd filters every 300 hrs
/ T554 tym #20
The ONLY good filter of those is the Hastings the others are crap at least for cars and I don't think it's any different for tractors.
CAT 621B Transmission (A68134)
CAT 621B...
TWO PALLETS OF HYD TANK, V8 ENGINE BLOCK/PARTS (A67714)
TWO PALLETS OF HYD...
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
2013 CHEVROLET CAPRICE CAR (A66091)
2013 CHEVROLET...
2024 Kubota L47 T.L.B. 94HRS FOR SALE loaded w/options & $17K off new at $63,900!
2024 Kubota L47...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
