T5070 4wd not working
   / T5070 4wd not working #1
ljohnson778
Platinum Member
Upstate NY
New Holland T5070
Quick question for anyone who can chime in... I particularly hope RickB sees this, as I know he is a wealth of NH information. I bought a new T5070 in August. I really love this tractor, it is a beast. I only have about 20 hours on the clock, and have had no reason to use the 4wd. I got it back Friday from having the loader installed, and decided today to push out some small trees that had to go. I flipped the 4wd switch, heard something engage below the tractor(same sound as when applying brakes, as 4wd engages during braking) and commenced pushing. Funny thing is, rear wheels spun, and front did not. So off to muddy hill to test... In 4wd, going up, rear tires spun, front did not. Coming down, applying brakes, rear tires locked, front did not. I called the dealer, and they will correct whatever the problem is, they have been great to deal with. My question is, anyone else ever see anything like this? I can hear something actuating when I apply brakes or flip 4wd switch, but no 4wd...
   / T5070 4wd not working #2
Maybe one of the front driveshaft couplers has slid out of position and is disengaged from the front pinion or drop box output shaft. A missing or misplaced snap ring will allow this.
Thank you, I'll post back when it's fixed.
OK, wow... That's all I can say. You really nailed it, spot on. Out of curiosity, I crawled under the tractor for a look. Sure enough, the coupler between the pinion shaft and driveshaft was slid back on the driveshaft, completely disengaged from the pinion shaft.
I'll say two things... One, thank you, this is a major relief. Two, you REALLY know your stuff.
Thanks again,
Larry
   / T5070 4wd not working #5
Thanks again,
Larry
You're welcome. I've got quite a few Tee shirts hanging in the back of the closet; that's one of them.
(You know, been there; done that, got the tee shirt.)
Update: Tech came out to my place today and repositioned the coupler and replaced the snap rings. All is well, works like a charm.
Thanks again RickB.
Golf Cart (A51694)
Golf Cart (A51694)
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2020 CASE IH 110N LOT NUMBER 222 (A53084)
2020 CASE IH 110N...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2018 New Holland T8.350 MFWD Tractor (A53342)
2018 New Holland...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
