T413 Dashboard problem
   / T413 Dashboard problem #1
Sweetas
MelbourneVictoria
990 pasquali
I own a two year old TYM T413(393), with 206hrs, that the dashboard has stopped working. The centre symbols light up as normal, but I have lost the tacho, hour meter, temp gauge, and fuel gauge. After checking all the obvious things, like fuses, relays, wiring harness for broken or damaged wires etc., I took the dashboard to where I bought the tractor from and they fitted it to another t413 and it seemed to work, albeit that the gauges were not showing the correct values, (out by roughly a 1/4). They said it would NOT be covered by the three year warranty, (God only knows why?) and charged me $130 AU to check the dashboard. The company that I bought it from, want me to take the complete tractor to them so they can possibly find the cause, but I am reluctant to do so as I can only imagine what they would charge to go over the whole tractor? They have generally been less than helpful. Is anyone here able to shed some light on this problem, or guide me to what else I might try, or even perhaps experienced the same issue with their dashboard? Thank you in advance. Dave.
   / T413 Dashboard problem #2
If that tractor was stateside, my first question would be, has someone disconnected the data logger associated with the DPF?
   / T413 Dashboard problem #3
Check for Voltage to the fuse for the instruments. AFter it is probably a voltage regulator. All the gauges you lost are the ground sensor ones, and have a common electrical feed through the one fuse. So begin by checking voltage before he fuse, and after the fuse, if you have he 12-V there, follow the wire looking for damage. Some where you will find an open which is preventing the cluster from getting power.
   / T413 Dashboard problem #4
I have A TYM T413 with just below 300hrs. After a half day use the tractor was parked. On the next attempt to start the CHECK light flashed with no start at all. Found that water separator had lots of water. Cleaned the water separator up along with the sensor. Checked the fuses and replaced 2, but still the CHECK light turns on and no start although all dashboard appears to work. There was lots of debris caught in the fuse box. Our area is in humid tropics. There was no apparent fault with the fuses I replaced, just dust and perhaps slight signs of corrosion on the contacts, but the 2 I replaced reactivated the circuits these were protecting.
Now proceeding with cleaning contacts in the fuse box.
Dealer recommended to check voltages at fuses and all sensors to establish that these are getting power.
Will post further as progressing through the fault finding.
I welcome any comments/ solutions you may propose?
132936 (A44391)
132936 (A44391)
1999 Progressive Industrial 25ft Tug Boat (A44571)
1999 Progressive...
INOP/NON-RUNNING Cat D3C Crawler Dozer (A44391)
INOP/NON-RUNNING...
2019 KENWORTH T880 (A45046)
2019 KENWORTH T880...
2005 IMS 5012 LP VERSI DREDGE (A45046)
2005 IMS 5012 LP...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A44391)
2013 International...
