T4050 Air conditioning compressor not coming on
/ T4050 Air conditioning compressor not coming on #1
cecil55
Ontario
New Holland T4040
The air conditioning on my T4050 is not working. I checked the system and there appears to be a sufficient amount of refrigerant but the compressor will still not engage. Anyone know if there is a fuse somewhere to check or what else could be causing the problem? Thanks
/ T4050 Air conditioning compressor not coming on #2
How you go about checking pressures if compressor clutch won't engage? I located a resister close to blower motor in parts schematics. Have you checked for a blown fuse or tripped circuit breaker?
I just had a gauge on the low side port. There is no fuse for A/C that I can't find in main fuse box.
/ T4050 Air conditioning compressor not coming on #4
A/C fuses and relays, probably aren't in the main panel. Look on the cab post between right side door and side window.
Just curious, what was the pressure you say was "sufficient" on the gauge you were reading? Do you recall the approximate ambient temperature the day you were working on it?
/ T4050 Air conditioning compressor not coming on #5
Or check for power to the low pressure switch, with the key in the run position, the fans on and the AC selected.
It may need to charged higher to make the low pressure switch.
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
2004 GMC 5500, Duramax Diesel Truck Vin# 1GDE5E1234F520387 (A62679)
2004 GMC 5500...
2014 Chevrolet Traverse (A62613)
2014 Chevrolet...
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
2015 PETERBILT 567 TANDEM AXLE DAY CAB (A66091)
2015 PETERBILT 567...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
