T4040 vs T5040
   / T4040 vs T5040 #1
jskibi
I'm having a tough time thoroughly comparing these two tractors from the online website. I was hoping someone could point out the major differences between the two because the price online is roughly the same as a base unit. I'm guessing the T5040 is the sturdier tractor but are there any other major differences?
   / T4040 vs T5040 #2
The T4000 and T5000 series tractors are NH's "premium" line. Much nicer than the TD's, TT's and Workmasters. Either one will be a really good tractor. I have a 2007 model TN70A. It's been a great tractor, so far. Never had an issue. It's never been back to the dealer. Easy to operate and fuel effecient. The TN-A series was replaced with the T4000 series in 2008. (basically the same tractor)
You really need to see them, in person, side by side. The T5000 is considerably larger than the T4000. It's also heavier by 1200 pounds or more, depending on options like FWD or cab. The larger, heavier tractor will have more 3-pt hitch lift capacity, more FEL capacity, and will ride better than the T4000. On the other hand, the smaller tractor will be more nimble and easier to get into tight places.
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
Polaris Sportsman 500 (A51573)
Polaris Sportsman...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A52576)
2016 VOLVO VNL300...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2015 International DuraStar 4300 26ft. Box Truck (A51692)
2015 International...
