T4040 vs T5040
   / T4040 vs T5040 #1
jskibi
I'm having a tough time thoroughly comparing these two tractors from the online website. I was hoping someone could point out the major differences between the two because the price online is roughly the same as a base unit. I'm guessing the T5040 is the sturdier tractor but are there any other major differences?
   / T4040 vs T5040 #2
The T4000 and T5000 series tractors are NH's "premium" line. Much nicer than the TD's, TT's and Workmasters. Either one will be a really good tractor. I have a 2007 model TN70A. It's been a great tractor, so far. Never had an issue. It's never been back to the dealer. Easy to operate and fuel effecient. The TN-A series was replaced with the T4000 series in 2008. (basically the same tractor)
You really need to see them, in person, side by side. The T5000 is considerably larger than the T4000. It's also heavier by 1200 pounds or more, depending on options like FWD or cab. The larger, heavier tractor will have more 3-pt hitch lift capacity, more FEL capacity, and will ride better than the T4000. On the other hand, the smaller tractor will be more nimble and easier to get into tight places.
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
FRONTIER AH11G LOT NUMBER 112 (A53084)
FRONTIER AH11G LOT...
2005 TerraGator 8104 (A53472)
2005 TerraGator...
2012 PETERBILT 587 SLEEPER (A52577)
2012 PETERBILT 587...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
