T4.75 won't reverse
/ T4.75 won't reverse #1
rush creek
St.Croix USVI
ford 7600 / kubota L2850 / John Deere
Good night, I have a New Holland T4.75 but it wont reverse. The shifter will go in forward neutral and reverses . The tractor would drive forward go in neutral but just wont reverse. There is no noise coming from the transmission when I select reverse. can someone help me please
/ T4.75 won't reverse #2
Sounds like there is something wrong with either the hydraulic clutch pack for the reverse itself or the electronics wiring going to it.
thank you I will check it out
B
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A60352)
2014 Chevrolet...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
Pick up Bed (A60352)
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A61307)
2022 Greenworks...
Giyi SE61 QA Broom Sweeper (A60463)
Giyi SE61 QA Broom...
