T4.75 Diesel Particulate Filter (DPF) Regen Failure - is there a fix I can do or is it dealership pain time?
   / T4.75 Diesel Particulate Filter (DPF) Regen Failure - is there a fix I can do or is it dealership pain time? #1
KevinAr
New Holland T4.75
Hi;
My 2017 New Holland T4.75 with ~ 1000hrs on it has decided to fail the DPF Cycle, It tried a few times in Auto, Failed, then I started to get the warning messages. So I used the manual and went through a manual regen process (it failed), I tried a second time, and foolishly touched the throttle so the manual regen process failed. Now the software has blocked my ability to initiate a 3rd manual regen. The menu is no longer available from the tractor menus.
The tractor now is showing the RED STOP error messages for the DPF system.
Q1: Is there a way to reset the system to try again? Like disconnecting the battery or does the system have Non volatile memory that will just remember that its in error? Or is there a hard reset button like on a router?
Q2: It wouldn't bee all that hard to remove the DPF and clean it on my own. I would be careful not to damage sensors, or screens, has anyone been successful at this?
Q3: Is there a way to bypass all this nonsense - like are the sensors switch based / contacts so I could just "Trick them" to thinking the DPF is always clean or is it a 4-20ma (or 0-10VDC) signal that I wouldn't be able to trick.
I'm not keen on having to going to the dealership but I think I may be forced to if it's a software thing, because I don't think I can buy a diagnostic tool for the tractor.
Any guidance appreciated.
Cheers
Kevin
   / T4.75 Diesel Particulate Filter (DPF) Regen Failure - is there a fix I can do or is it dealership pain time? #2
There is aftermarket software and hardware available on ebay and amazon. Search for New Holland Diagnostic software. We purchased a kit with the interface, cables, NH EST software installed and a laptop because our T4.90 kept throwing stop codes and we didn't want to wait for the dealer to come every time or the charges involved. Look for one with latest software update. Paid for itself first time we used it no travel time/mileage from dealer to pay. NH will not sell you the software or interface etc
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A57880)
2018 VOLVO VNL...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A55315)
Mahindra 4550-4L...
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
