T394 Fluid capacities and filters...
   / T394 Fluid capacities and filters... #1
The Chairman
TYM
Pretty self-explanatory. I want to know how much to buy and I can't seem to find the info anywhere.
Engine oil
Hydrostatic oil
Antifreeze
Oil filter brand/number
Hydrostatic filter brand/number
I just fixed 2 hydraulic leaks and have dumped in 3 gallons of hydraulic fluid and I'm still not seeing it in the site glass. Could I have it so full that I'm over the site glass?
   / T394 Fluid capacities and filters... #2
Engine oil
Hydrostatic oil
Antifreeze
Yes it could be over filled, What I do is have some one raise the loader while you look at the sight glass, and see if it draws down. But I think 3 gal. of oil may be to much for it to come down.
If you are ready for a service you might want to start over and just drain it.
Your operators manual has a capacity chart
15w40 eng oil, A good quality utf/mtf oil high spec like jd j20c Kubota udt
I recommend getting oem filters from your local dealer
OK, I finally found these, so I will answer my own question...
Fuel tank; 9Gal or 34L *Low or Ultra Low Sulfur Diesel
Cooling system: 7Qt or 7.4L *Antifreeze & Water mix
Crankcase: 6Qt or 5.7L *SAE 10W40 API CJ-4 (Diesel Oil)
Trans & Hydr: 9.25Gal or 35L *???? I don't find a spec for this oil
Front Axle: 8.7Qt or 8.2L *SAE 90W API GL-4 (or higher)
I still don't have a good lead on filters yet.
   / T394 Fluid capacities and filters... #4
For your filters
ENG OEM Yanmar 129150-35170
Fuel OEM Yanmar 129a00-55800
Fuel OEM yanmar 129a00-55730
HST OEM TYM 15532302100
AIR we use Baldwin rs3705 & rs3704
Fluids
Fuel you have it correct
Coolant correct 60/40
Crankcase is printed 6qts, you will find 4.25 will fill it. Use 15w40
Trans is printed 9.25 gal,that is wrong closer to 7.5 gal use a utf matching jd j20c or Kubota udt
Front axle correct 80w90
Just a question Why is it you say you don't have a good lead on filters yet?
You bought the tractor from a dealer right?
The OEM filters for that yanmar eng are priced less than napa/wix, and there is no issue.
Our dealership we only sell local, that way we provide full service to who we sold to.
Let your local dealer provide you with his service, He will appreciate it.
The dealer I bought this tractor from is over 60 miles away. Driving there is problematic for me. Great people, but really, I would like to drive a little, not a lot to get parts or have them delivered here. I tried ordering parts from them, but they have sent me the wrong stuff twice now. Mega thanks for the part numbers.
2022 KMC 5610 LOT NUMBER 212 (A53084)
2022 KMC 5610 LOT...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A53472)
2012 KINZE FLAT...
2023 CATERPILLAR 299D3 SKID STEER (A51246)
2023 CATERPILLAR...
NEW Fork Extensions (A53002)
NEW Fork...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
