T300 Battery Draining - Code 17-07
   / T300 Battery Draining - Code 17-07 #1
Drug Man
White Lake, MI
Bobcat T300
I have a T300 and battery keeps draining. I got a new battery and new alternator. Worked for a while and now is draining again. I put it on trickle charge overnight and will work for a couple of days before draining again. Any Ideas?
Also, moving dirt the other day and bucket would not lift or tilt. Light came on and gave me code 17-07 (hydraulic lock valve open circuit). Do you think its a bad solenoid?
   / T300 Battery Draining - Code 17-07 #2
17-07 code could be bad solenoid or loose pin in a connector or broken wire in the harness. Without taking some ohm readings and continuity tests you without just starting to replace parts by guess.
Thanks. I'll try to take some readings. Any idea why the battery keeps draining?
Pallet Fees (A50775)
UNUSED AGT QUICK ATTACH AUGER SET (A51248)
UNUSED AGT QUICK...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
UNUSED FUTURE PC711 - 71" HYD PLATE COMPACTOR (A51248)
UNUSED FUTURE...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
2017 Bobcat S70 Compact Wheel Loader Skid Steer (A51691)
2017 Bobcat S70...
