T273 fuel/ignition problem?
/ T273 fuel/ignition problem? #1
dday88
Clifton Springs, New York
TYM t273
Im having an issue when I turn the key on my 273 to the pre heat position the glow plug indicator is not lighting up and I get a constant clicking noise from my fuel pump. I looked all over for any exposed wires or shorts and most everything is in split loom or very well covered in electrical tape, but i did find a nice wear mark on a hydro line where it was rubbing on the fire wall.
Link to the vid http://db.tt/DRBGbK02
/ T273 fuel/ignition problem? #2
Check the battery ground at the chasis and check the battery terminals for corrosion.
/ T273 fuel/ignition problem? #3
T273s and 293s are known for shorts to ground where the dash board/ignition harness passes through the firewall. My 293 kept blowing the turn signal/emergency flasher fuse. A little slit 1/4" tubing around the hole prevented further chafeing. I use plastic foam water pipe insulation, held in place with plastic tywraps, to prevent hydraulic line chafeing.
2016 Chevrolet Tahoe SUV (A64194)
2016 Chevrolet...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
2017 Ford Fusion SE Sedan (A64557)
2017 Ford Fusion...
2017 INTERNATIONAL 4300 4X2 S/A 26FT NON CDL BOX TRUCK (A67147)
2017 INTERNATIONAL...
2021 LUCON MRT3500 SPOOL TRAILER (A63276)
2021 LUCON MRT3500...
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
