T25 Fuse identification
   / T25 Fuse identification #1
Kgkessler
TYM T25
I have a brand new T25 that ran for about 2 hours then stalled and will only run briefly then stop. I found that whenever I start it it blows a 7.5 amp fuse. The fuse is labeled “E/G STOP”. Can anyone tell me where i can check to correct this. I have no idea what E/G STOP indicates. Thanks!
   / T25 Fuse identification #2
check your wiring for a short against your frame or wet or maybe mouse damage.
The wires I am thinking about come from the connector that is to the left and slightly higher than your engine oil dip stick. (rhs tractor near floor board)
Check to see if wet or insulation rubbed off/eaten etc....
let us know what you find
2014 John Deere 630FD Draper Head (A53342)
2014 John Deere...
2018 John Deere 310L 4x4 Extendahoe Loader Backhoe (A52377)
2018 John Deere...
2000 New Holland TN65 Tractor with Loader (A51573)
2000 New Holland...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2008 IC Corporation PB205 Bus, VIN # 4DRBVAANX8A506494 (A51572)
2008 IC...
2020 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A52576)
2020 FREIGHTLINER...
