T2420 versus T4020
   / T2420 versus T4020 #1
wolfgreyt
NH 4060
Looking at moving up to 60 hp tractor with cab ( I should have got cab in first place)from my TC45DA.( no cab) I am interested in any suggestions /comments on the T2420 versus T4020.I do mostly FEL work, lots of heavy brushcutting on rough pasture. I would like to start some plowing and doing some small square baling work in future.I have about 40 acres of paddocks to maintain.
   / T2420 versus T4020 #2
I'm not at work right now, but we have each model in stock. I'll look at 'em side by side and give you my impression.
From memory, the T4020 is a whole lot bigger with more features, at least I think.
I still get so confused on the T2310, T2420, T2120, T???, so I might be thinking of the wrong "T" but we just got the T4020 and I was kinda impressed by its size. Back at ya later.
   / T2420 versus T4020 #3
The T2420 weighs in at 3,408 (less tires), and the T4020 weighs 4,980.
Side by side, they don't look that much different in size. I had thought the T4020 was a bit bigger, but I'm surprised to see just how much heavier it is.
They're both 50 PTO hp, by the way.
   / T2420 versus T4020 #5
If we are talking about the same Boomer 2420 / 4060 then the spec sheet says it's shipping weight is 4260 lbs.
I think shipping weight includes tires/wheels. The 3480 lb is without tires. I think thats very close to the difference to the 4260 lb.
   / T2420 versus T4020 #6
Specifications show the T2420/4060 ROPS FWD is 4,260 lbs. and the T4020 ROPS FWD is 6,327 lbs.
  • Boomer_Ut_specs_062708.pdf
  • T4000_specs_013108.pdf
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
CAT 973 (A47384)
CAT 973 (A47384)
2023 GMC 3500 Bed (A51573)
2023 GMC 3500 Bed...
2015 TRANSMASTER LOWBOY TRAILER (A52576)
2015 TRANSMASTER...
