T24 Baler Twine
   / T24 Baler Twine #1
Eyzek
John Deere T-24 Baler
Hello everyone,
I need to buy Square Baler Twine #130 but can only find #170 and up, does anyone know if there is a change in thickness between the two?
Thank you for your time.
   / T24 Baler Twine #2
There is a nominal change in thickness, however I found that my 24t works better with the 170# twine. I was using 130# twine but started breaking a lot of bales after they had exited the baler. I tried adjusting everything and nothing helped so we went with the heavier twine and have had good luck.
   / T24 Baler Twine
Thanks! I'm sending it my dad and he says he needs #130 or else the twine gets stuck, I dont know what he means by that but I'll let him know that you use #170, ill be seeing the baler soon so ill know what hes talking about. Thanks again.
   / T24 Baler Twine #4
130 twine is for round bales not squares. Stick with the 170.
   / T24 Baler Twine #5
All I've ever used in a 14T and a 336 for small square bales is Orangeline BT-130 and John Deere 130. 170 is thicker and used for round bales.
   / T24 Baler Twine #6
170 is not used for round bales. 20,000/110 or 16,000/110 is round baler twine. 170 twine is a higher knot strength alternative to 130 and is used in small square balers for straw bales, or in instances where heavier bales and higher knot strength are desired.
If a baler's knotter will tie 130 twine reliably, there is no reason to think 170 twine would cause any problems or require any adjustment beyond POSSIBLY reducing the twine holder tension incrementally.
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2 1/2 Ton Military Truck, 6x6, 16' Flatbed (A52384)
2 1/2 Ton Military...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
2016 Nissan Altima Sedan (A51694)
2016 Nissan Altima...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
