T20 starting problem
   / T20 starting problem #1
haselhorst
Fergeson T20
I believe to start the T20 you have to push the shifter up to the right? I have not been able to start it this way and I have to short the solenoid. Is there an adjustment or ? Thanks
   / T20 starting problem #2
:welcome:
Is this a Ferguson TO-20?
Yes, when I bought it it was in a corral with horses and I had to repair most of the wiring. I can start it by using a screwdriver across the bolts on the relay but I can't start it using the shifter, I guess? I looked at youtube and it looks like they use the shifter some how.
   / T20 starting problem #4
You could add your own starter - push-button on the dash to close a solonoid to close the hot to the starter.
Or you could dig into the tranny and fix the mechanical switch (as I remember it anyway).
Do you have the I&T shop manual for the TO's ?
   / T20 starting problem #5
G'day from memory lift the stick up and all the way over to the right and forward to start if this does not work the switch just unscrews from the trans to replace it but if i remember right they are not cheap and have replaced a few as stated with a push button switch
Jon
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52748)
Gooseneck...
2012 Kia Sorento SUV (A51694)
2012 Kia Sorento...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2024 JOHN DEERE 8RX310 LOT NUMBER 77 (A53084)
2024 JOHN DEERE...
2008 CATERPILLAR 226B2 SKID STEER (A51246)
2008 CATERPILLAR...
