T1560 maintenance Qs; + tranny fluid?? + engine compatability
   / T1560 maintenance Qs; + tranny fluid?? + engine compatability #1
canucklehead
frozen Canada
1979 Ford 1500, Toro 455D 10' mower w/ Renault diesel,
I have 2 T1560 ride on mowers I just bought. The second is for parts, but I'm considering finding a motor for it (the case/block is broken). So far, the working unit seems great, the grass catcher works great and it does a nice cut, especially for something so badly neglected.
Does anyone ever change the HST fluid? I believe there is a filter screen...not sure where. Do you take that out and clean it? Is there a drain plug, or is it a major job to take it apart to re&re fluid? [rhetorical question, but why do they make it so hard to change fluid?]
A bit disappointed that an oil filter is an "optional" add-on kit. I have ordered the kit. I assume it mounts under the air filter box,with filter spinning on near the carb float bowl.
I changed plug, air & fuel filters, oil. Wheel bearings are shot and so is a tie rod. Are there any other maintenance items or things to keep an eye on?
These use a Kawasaki 14 HP motor, seems to be the exact same engine that John Deere uses in several of their mowers. My second mower is good, except the motor is FUBAR. A local guy has a Kohler 15HP engine that came out of a JD LT155 mower. Would I be able to swap this out and put it in, relatively easily? Ironically, I had a JD 155 about 1-2 years ago. It ran good, Kohler is a good engine, but the mower deck configuration was awful. I chewed through belts like crazy. No matter how I tried to trim bolts and reduce/avoid belt rub, the main belt always found a way to rub on something and never lasted. It was a royal PITA.
sorry, too much info and lots of Qs!! thanks for any help.
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
2023 JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
2023 JOHN DEERE...
2017 SKY TRAK 6036 TELEHANDLER (A52576)
2017 SKY TRAK 6036...
9202 (A50322)
9202 (A50322)
2020 JOHN DEERE 5125R LOT NUMBER 213 (A53084)
2020 JOHN DEERE...
