Oil & Fuel T1510
   / T1510 #1
stokedog
I recently purchased a T1510. The tractor starts fine but barely has any power under a load. It seems as if it is not getting enough fuel. I cleaned out the fuel filter and even bypassed the filter and still no power. Any suggestions?
   / T1510 #2
I'm definitely not an expert... but here's a few questions to help troubleshooting:
1. Is it Hydro or manual?
2. if manual does it react the same in L/M/H
3. What is the load - bucket filled with dirt
4. Have you tried increasing the RPM
5. Do you find it slow when moving around, or lack of power on the hydraulics.
The T1510 is 30 HP, therefore it does have its limits, but still can do a lot of decent/heavy work.
   / T1510 #3
Make sure there is not something in the fuel tank restricting flow. Also make sure the diesel is still good.
Gary
   / T1510 #4
Crack the fuel return line at the front injector 'till the bubbles stop. BTDT every time I changed a filter on 1520 & T-1520. Hoping that's all you need.
Air filter/tract ok?
A first HST? 'Power' expected in High Range (~'travel gear') won't do much, if any, work.
btw, :welcome: 'Comin' back?' tog
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
2008 New Holland B110 MFWD Loader Backhoe (A52748)
2008 New Holland...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
2016 LT63 Towable Light Tower (A51691)
2016 LT63 Towable...
