Oil & Fuel T1510
   / T1510 #1
stokedog
I recently purchased a T1510. The tractor starts fine but barely has any power under a load. It seems as if it is not getting enough fuel. I cleaned out the fuel filter and even bypassed the filter and still no power. Any suggestions?
   / T1510 #2
I'm definitely not an expert... but here's a few questions to help troubleshooting:
1. Is it Hydro or manual?
2. if manual does it react the same in L/M/H
3. What is the load - bucket filled with dirt
4. Have you tried increasing the RPM
5. Do you find it slow when moving around, or lack of power on the hydraulics.
The T1510 is 30 HP, therefore it does have its limits, but still can do a lot of decent/heavy work.
   / T1510 #3
Make sure there is not something in the fuel tank restricting flow. Also make sure the diesel is still good.
Gary
   / T1510 #4
Crack the fuel return line at the front injector 'till the bubbles stop. BTDT every time I changed a filter on 1520 & T-1520. Hoping that's all you need.
Air filter/tract ok?
A first HST? 'Power' expected in High Range (~'travel gear') won't do much, if any, work.
btw, :welcome: 'Comin' back?' tog
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A56857)
2024 AGT LRT23...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2012 Ford F550 (A55973)
2012 Ford F550...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
2023 Kubota U55-5R1 Mini Excavator (A55315)
2023 Kubota...
