T1510 Squealing Sound
   / T1510 Squealing Sound #1
ChuckTyler
Oakdale, CA
NH T1510
Hi Folks. I'm new to this forum, but hope y'all can help. My NH T1510 has 400 hours on it, and noticed today that as I push down on the hydrostat pedal to increase speed, I hear a squealing noise that seems to be coming from the front. If I ease up on the pedal, the sound goes away. It seems to be more prevalent in the Medium and the High Ranges; I don't hear it in the Low Range.
Have any of you come across this?
Thanks,
Chuck
   / T1510 Squealing Sound #2
Assuming it's FWD, grease the drive shaft. There are bushings in the shaft that will squeal in they get dry.
Thanks for the info Agriman. I'll give it a good lube job today and see if that resolves the problem.
   / T1510 Squealing Sound #4
I just posted the same issue with my JD 4120. Curious to see what you find out. I'm thinking a relief valve?
Sorry, Jmer817, I haven't got to it yet. My wife's 98 year old uncle is living with us, and the last few days have been kinda rough. Hopefully tomorrow. I'll let you know.
Well, I finally crawled under the tractor and it turns out that all it was, was the boot that covered the front U-joints on the driveshaft tore loose and the clips that hold it in place were rubbing when the shaft rotated. Should have looked earlier, but it's tough for this old body to lay down on the ground, let alone get back up.
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
Quick Attach Hydro Slide Pallet Forks (A50514)
Quick Attach Hydro...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
2011 VOLVO VNL670 SLEEPER (A51219)
2011 VOLVO VNL670...
