T035 oil pressure
   / T035 oil pressure #1
Cougsfan
Eastern Washington State
Ferguson TO35, Branson 4720CH
My FergusonTO35 standard diesel has 21 hours on it since a major overhaul. The thing runs like a top, but has one concerning issue. When the engine firsts starts it has 60 psi oil pressure. Once it is running it slowly starts to drop . After 15 to 20 minutes of operation it falls all the way to 15 psi and stays there.
I put 10-40 Dello in it originally, and changed it to straight 30W to see if it would help, it didn't.
Seems like the drop in pressure is way to much to attribute to reduced oil viscosity at temperature. Its like a hole somewhere in the oil system opens up when it gets hot. Any ideas on where to look?
   / T035 oil pressure #2
What did you set the main and rod bearing clearances at? The straight 30w has lower viscosity at op temperature than the 10w-40 so the problem will not be helped. To do what you're desiring, try 20w-50 or a straight 50w.
STORAGE FEES (A52576)
20ft x 20ft Steel Carport (A51573)
20ft x 20ft Steel...
Ford NAA Jubilee Tractor (A53472)
Ford NAA Jubilee...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2014 Doyle Dry...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
