T-Rex - my towable wood chipper
   / T-Rex - my towable wood chipper #1
ruxu
Finland
Suzuki SJ MPV
Finally!
I have earlier asked here and on some other forums for advice on chipper feed hydraulics. Now I have finally got my wood chipper made ready - although I am retired it took me over 13 months. The whole project started from this,
and ended up with this towable hydraulic feed chipper
Initially I made the chipper with manual feed but first tests showed that it did not work very well so I decided to redesign it to hydraulic feed. As I had to buy the hydraulic parts as new the whole project budget was doubled.
The chipper is powered by a 16hp Briggs&Stratton cast iron engine from 1979. The axle and frame is from a old homemade trailer from 1980. The chipping wheel diameter is 500mm and thickness 20mm and fitted with two chipping blades. The weight is about 32 kg and it rotates at 1 300 rpm. The engine axle has a centrifugal clutch with two V-belt groves with diameter 90mm. The chipping wheel pulley diameter is 180mm. The hydraulic pump with a flow of 7,4 L/min. is also driven from the chipping wheel axle.
The infeed rollers are driven by 250ccm gerotor motors. The direction of the motors are controlled by two solenoid valves. A flow divider is also fitted to make it possible to adjust the infeed roller speed. Additionally an Arduino microcontroller is via an inductive sensor fitted to read the chipper wheel speed. If too heavy load is applied and the chipper wheel speed drops below a set rpm value the microcontoller cuts voltage to the infeed roller solenoids until the chipper wheel gains enough rpm again. The chipper is capable to chip wood up to a diameter of 125mm.
The feed table edge to indeed rollers is 1 250mm to meet CE safety regulations. An infeed cutoff bar is fitted around the feed table edges. Emergency stop switches are fitted above the infeed and on the control panel. The chipper wheel housing cover is also fitted with a safety switch.
The towable chipper trailer base is re-registered as a towable machine and it is now allowed to tow it on public roads. The total weight of the chipper is 380kg.
Here are some additional pictures taken during the project.
   / T-Rex - my towable wood chipper #3
Wow, that looks just like my Bear Cat Chipper. Nice work
   / T-Rex - my towable wood chipper #4
+10 on impressive! What sort of occupation did you retire from if you don't mind my asking? From the paint to the electronics to the decals, awesome!
   / T-Rex - my towable wood chipper #5
That is very well done.
   / T-Rex - my towable wood chipper #6
That's some nice work, how's the engine hold under load? I used that same engine on my garden tractor puller back in the day.
Are you running the engine at the rated 3600rpm? Unless I missed something I calculated flywheel speed at 1800rpm instead of 1300
Wow that is really well done. How fast does it feed?
The maximum design feed speed is about 18,2 m/min. The flow regulator is however now set on maybe a little over half the range so it should be around 10 m/min.
There is actually four things that can be adjusted to get optimum performance,
- the engine speed - now set to about 2 700 - 2 800 rpm
- the hydraulic pressure - now set to 80 bar
- the setting of the flow regulator - now set to about 60% flow
- the Arduino micro controller feed control software - the chipper wheel runs at 1 300 rpm, too hard feed rate warning at about 1 100 rpm, feed interrupted at 1 000 rpm
As I get more experience how the chipper works I will probably adjust some of the settings.
Well... you now it is no use to re-invent the wheel...
When I started to design the chipper I of course looked on all available material of commercial chippers. I basically evaluated different solutions based on,
- how well will it work
- how hard is it to make with the tool limitations I have
- how much will it cost
My feed mechanism idea is certainly influenced by the Bear Cat chipper. I selected this approach because constructions that had the upper feed roller fitted to a linkage that was fitted to the infeed frame had so many parts fitted with various angles that I evaluated a little bit hard to make.
I have one question to you. How often do you grease/clean the moving upper roller frame of your Bear Cat chipper?
Thank you very much!
I retired about two years ago from a position as a manager of an R&D department of a Finnish company making equipment for commercial kitchens. Even as a manager I often grabbed the tools to solve things together with my team. The painting experience is from my teenage+ years when I repaired and repainted damaged cars to get a decent daily driving vehicle. As for electronics it has been a hobby of mine all my life but also the commercial kitchen appliances almost all involved some kind of electronics. I have also done a lot of illustrations for product manuals.
The idea of the chipper is basically to cut branches that are too small as firewood so that is probably everything under 40...50 mm. Cutting them doesn't affect the engine speed at all.
I have tested the chipper with some pieces of 100...110 mm wood and then the engine speed drops a little bit. During those tests that I made before the chipper was painted I did not have the Arduino micro controller feed system fitted so I don't know how the infeed would have made pauses then.
From information I have found the B&S 16hp engine has the best torque at around 2 700 rpm so I run it on that speed. Thus the cutting wheel speed is around 1 300...1 350 rpm.
New Wolverine Skid Steer Root Rake Bucket Attachment 34'' (A53002)
New Wolverine Skid...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
Misc Power Tools (A51573)
Misc Power Tools...
2017 International Prostar Sleeper Truck Tractor - Cummins ISX 15 Engine - 10 Speed Eaton Fuller (A53472)
2017 International...
2009 Kubota KX080-3 Mini Excavator (A51573)
2009 Kubota...
