System Hydraulic Pressure Test
/ System Hydraulic Pressure Test #1
rwork
Platinum Member
Mississippi Gulf Coast
Kubota B6100 LS R3039H
I got my hydraulic pressure gauge from Surplus Supply, now just need to try it out. I'm guessing I'll just plug it into one of my rear remotes, and open the control lever, and I should see the system pressure??
Factory pressure is supposed to be 2242 psi. If it isn't, I'll have to try and figure out how to adjust it. Maybe someone who has adjusted their LS will chime in on how to do this.
/ System Hydraulic Pressure Test #2
You should know the tractor relief pressure, and then plug the gage into any valve work ports QD's, and hold the lever at max, you will see the relief pressure.
The first valve in the hyd system should be the master relief, and all the other relies set the same.
I checked my system pressure today, and got a reading of about 2250 psi @ pto speed. According to the manual it should be 2422 psi. I'm about 175 psi low. Should I increase it, or let it be?
/ System Hydraulic Pressure Test #4
Force
7609 lbs at 2422 psi
7,069 lbs at 2250 psi.
It is up to you if you want to bring it back up to specs.
Here's what I think is the relief valve, however, I'm not certain, nor do I know how to adjust it.
/ System Hydraulic Pressure Test #6
Yep, that is the valve relief valve.
If it is the adjustable kind, you connect a hyd gage in the system and run the tractor about mid rpm range, and adjust the pressure according to factory specs or whatever you need. Turn in to increase pressure.
If the relief valve has shims, you turn tractor off and remove the relief cap and parts and add the correct shims for the pressure you need. The shims come in different sizes . You might get 2 to 3 shims in a kit, so choose which one you need or use all if necessary.
TIGER MOWERS TRF102-102" REAR FLAIL MOWER (A63276)
TIGER MOWERS...
2017 Ford Explorer SUV (A64557)
2017 Ford Explorer...
2003 Jeep Wrangler 4x4 SUV (A64557)
2003 Jeep Wrangler...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
2022 EZ-GO ELITE...
PALLET OF AXLE TAKE OFF'S & CYL (A64278)
PALLET OF AXLE...
