Synthetic oil hard to burn?
   / Synthetic oil hard to burn? #1
Rod in Forfar
Platinum Member
Forfar, Ontario, Canada
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
A couple of days ago I had to light a fire in a box stove in the garage when there wasn't any kindling nearby, so I poured a small amount of used engine oil onto the cherry blocks and started the fire. The fire built slowly, but I thought little more of it.
Today I tried a couple of ounces from the same jug on a mixture of green ash and Manitoba maple (box elder) in my workshop and discovered that the stuff would barely burn on its own. I'm pretty sure the oil was Rotella 5W40 synthetic out of my Bolens G174.
Has anyone else noticed synthetic oil's reluctance to burn?
   / Synthetic oil hard to burn? #2
it has a higher flash point...
   / Synthetic oil hard to burn? #3
yup- I noticed synthenic burns slower and cooler.
   / Synthetic oil hard to burn? #4
What is the flash point.?
   / Synthetic oil hard to burn? #5
Guys with used oil furnaces really don't like it.
   / Synthetic oil hard to burn? #7
I here the same thing. Problem I see is some of those guy have no idea what is in the "used oil".
   / Synthetic oil hard to burn? #8
Poulan Pro bar oil won't even ignite with a propane torch. Just like pushing around water on a flat surface with an air hose. Had a neighbor a few years back that poured some on his stab pile to get it going after he lite the pile and it put the fire out.
   / Synthetic oil hard to burn? #10
If you put synthetic oil in a waste oil furnace, you will never know.
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
UNUSED LANDHONOR 5/16" 7' G80 DBL CHAIN SLINGS (A54757)
UNUSED LANDHONOR...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2016 FORD F550 SUPER DUTY SERVICE TRUCK (A51406)
2016 FORD F550...
2001 JOHN DEERE 310G BACKHOE (A52705)
2001 JOHN DEERE...
2003 John Deere 310SG (A47477)
2003 John Deere...
