Synthetic Oil for PT 425
   / Synthetic Oil for PT 425 #31
"" ATH does not come up to the specs of the Kubota product ""
Unfortunately, it is not indicated which spec is not met!!
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil ATH is Recommended for Applications Requiring the Following Specifications:
Tractors
Case International - MS-1207, HYTRAN
Caterpillar - TO-2, TO-3
Deutz-Allis - All
Ford - M2C41-B, M2C134-D, M2C86-B
Hesston/Fiat - All
John Deere - Quatrol®, J20C, J20D, J14C
Kubota, UDT - All
Landini - All
Massey-Ferguson - M1127-B, M1129-A, M1135 and M1141 (also known as Permatran III®)
Steiger - All
Versatile - All
Transmissions
Detroit Diesel Allison Division - C-4 Hydraulic Systems
ABEX/Denison - HF-0, HF-1, HF-1A, HF-2, HF-2A
Cincinnati Milacron - P-70
Sundstrand - HMS-103
Sperry New Holland - 767166, 287530
Sundstrand Hydraulics, HMS-103
® Registered Trademarks
PERFORMANCE DATA
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil exceeds the following rigorous performance requirements:
Caterpillar Friction Retention Test - Pass
Denison Pump Test (T5D Vane Pump, 46 Series Piston Pump) - Pass
Deutz-Allis Friction Retention Test - Pass, Deutz-Allis Turbo Hydra-Matic Oxidation Test - Pass, Deutz-Allis Power Steering Pump Test - Pass
Ford 7710 IPTO Stall Test - Pass, Ford 7710 Brake Capacity - Pass, Ford 7710 Brake Chatter Test - Pass
John Deere JDQ-42 PTO Clutch (2000) Cycles - Pass, John Deere JDQ-40 Brake Capacity Test - Pass, John Deere JDQ-40 Brake Torque Variation (Chatter) - Pass, John Deere JDQ-73 Cold Soak @ -35°C - Pass, John Deere JDQ-74 Slow Cool @ -30°C - Pass, John Deere JDQ-74 Slow Cool @ -35°C - Pass
Massey Ferguson MF-285 PTO Clutch - Pass, Massey Ferguson MF-285 Wet Brake Chatter and Torque Characteristics - Pass
Plessy-Sundstrand Gear Pump Test - Pass
Sundstrand Model 22-2132 Variable Displacement, Piston Pump - Pass
Vickers 35VQ-25, Pump Test - Pass
I feel confident that ATH is far superior to the OEM MOTOR OIL used in the hydraulics of the PT!!!! /forums/images/graemlins/shocked.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/frown.gif
   / Synthetic Oil for PT 425 #32
"" What would be an average price for a quart, and a gallon of Amsoil oil ""
Contact: Lubrication Specialist
"" use the same oil in the hydraulic system?? ""
You wouldn't use Motor Oil in your car's automatic transmission, or ATF in its crankcase, because they are very different products designed to do very different jobs!! Likewise use Amsoil 0W-30 in your PT engine, and Amsoil ATH in your PT hydraulics!!
Changing 10 gallons of hydraulic oil may seem expensive, but it is a one time thing! Over the years if it prolongs top performance and extends useful life, it may be a very small investment! A lot of guys are into restoration. I prefer preservation!!
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Synthetic Oil for PT 425 #33
"" time to change over the hydraulic oil too? ""
At 100 hours the entire PT should be nicely broken in.
The theory is break it in long enough with dino oil to reach peak performance, and then convert to Amsoil to preserve that peak performance for as long as possible!
"" I hesitate to change over my car though since it has over 150k on it. ""
Do you plan to stop going to your doctor after your 50th birthday? If your car is running well, and has had regular maintenance, why not try to preserve its performance for as long as you can?? "Oil is cheaper than repairs!!"
   / Synthetic Oil for PT 425 #34
"" {OIL FILTER STUDY} ""
Please note that in this study:
"" AMSOIL SDF15 This filter has been acquired and is awaiting disassembly. "" /forums/images/graemlins/confused.gif
Check the oil filters compared in: SDF !
   / Synthetic Oil for PT 425 #35
"" You might have heard references to oil leaks developing at seals, and it's a possibility. ""
Check out "Myth #1: Synthetic motor oils damage seals." and "Myth #3: Synthetics cause cars to use more oil." in Ten Myths About Synthetic Lubrication !!
"" doesn't seem worth the expense for that small benefit ""
Check out "Myth #10: Synthetics are too expensive."
Also: The Unmeasureable Benefits of AMSOIL
   / Synthetic Oil for PT 425 #37
   / Synthetic Oil for PT 425 #38
   / Synthetic Oil for PT 425 #39
<font color="blue">" measured these stresses, called fringes, using what is called lazer holography." </font> I wonder if they use a laser for that? /forums/images/graemlins/grin.gif
Thanks for the links FOURTEEN. Pretty interesting reading.
   / Synthetic Oil for PT 425 #40
Different weights for summer and winter.
In reading the info from one of the links, it seemed like there wasn't a lot of value to changing your oil to a heavier weight in summer and lighter one in the summer.
I remember living in more extreme climates where we would change to a lighter weight oil in the winter so that the engine would turn over and to a heavier weight in the summer to provide more protection in the summer heat.
New/Unused Box of 10 Chains and 5 Binders (A57454)
New/Unused Box of...
AGRI X 6' ROTARY MOWER (A58375)
AGRI X 6' ROTARY...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
2013 FORD F-250 (A58214)
2013 FORD F-250...
