Synthetic oil befor 100hr?
   / Synthetic oil befor 100hr? #1
rja
new jersey
L3000dt Kubota
Has anyone used synthetic oil in a Kubota tractor prior to 100 hrs of use? I have been told that diesel motors don't need the brakein that gas ones do and that it is ok to use synthetic oil almost from day one. However, when I spoke to the Kubota factory tech, he said that I should NEVER use synthetic oil in their motors.??? Thanks, Rich.
   / Synthetic oil befor 100hr? #2
I put Mobil Delvac 1 in my tractor at the 50 hour change. The motor is broken in and the oil will cause no problems. The synthetic reduces friction but doesnt eliminate it. Therefore any breakin that calls for friction is still being donel.
Use normal maintainence and all will be well.
Good luck
Greg H
   / Synthetic oil befor 100hr? #3
At my 50 hr service, I put in Amsoil 15W-40 on the dealers recommendation. He also said I could double the time between service intervals if i wished.... Not so sure about that, tho...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A55301)
Michelin CARGOXBIB...
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A52706)
2016 CATERPILLAR...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2018 GENIE...
2014 Dodge 5500 4X4 Bucket Truck (A55218)
2014 Dodge 5500...
