Syncro-range Transmissions
   / Syncro-range Transmissions #1
Cossack1917
SW Pa
JD 2510 Kubota3010 MF65 DB990 JDA(Unstyled) Yanmar D155 Massey Harris 33
My buddy has been having some issues with his 3020 syncro-range. I took it for a ride today, and it feels like the shifter has gotten very sloppy, sometimes not going into gear. If you put it in park, then try it again, it goes in. Linkage problem? I don't know too much about the trannys in these new fangled tractors, as I'm a JD 2 cylinder kind of guy. Are we looking at big bucks at the JD dealer?
   / Syncro-range Transmissions #2
The shift quadrants on dash have been known to get slack in them and cause shifting problems. Shifter probably needs some shims & bushings. and maybe shift rod adjustments.
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A52377)
2021 Freightliner...
2007 JOHN DEERE 700J XLT CRAWLER DOZER (A52705)
2007 JOHN DEERE...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
