Synchro Shuttle shift lever operation on L3010 DT
   / Synchro Shuttle shift lever operation on L3010 DT #1
Logan
GA/ western NC
Kubota L3010DT
Is it necessary to use the clutch to shift from forward to reverse and back without clutching? The manual says it requires clutch operation. But...a friend was on it today and moved it back and forth several times without clutching and there was no gear grinding at all. I tried it once myself and it shifts just as well without the clutch as it does with it. Is the manual wrong or will this type operation eventually cause problems?
   / Synchro Shuttle shift lever operation on L3010 DT #2
The glideshift doesn't require the clutch to reverse direction.
But the sycro shuttle the clutch should be used.
Thanks Vince. I thought I knew that and I have always used the clutch, but my friends operation of it alarmed me, then puzzled me. There must be some very good synchronizers in there, so I'll try to keep them that way.
Electric Concrete Mixer (A51573)
Electric Concrete...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
Bandit Beast 4680 Horizontal Grinder (A51573)
Bandit Beast 4680...
TAKEUCHI TL230 SERIES 2 SKID STEER (A51246)
TAKEUCHI TL230...
2023 Chevrolet Express 2500 Cargo Van (A51692)
2023 Chevrolet...
