Swivel Fittings
   / Swivel Fittings #11
No, it was a joke on me. MB is a large New Hampshire tractor chain of questionable competency and horrible customer service (IMO).
   / Swivel Fittings #12
Hey /pine,
You are absolutely correct in your reply about using the wrong pipe fittings without the 30 deg chamfer.......I have seen many jobs in the past come in where some other repairman used the wrong fittings (without the chamfer) and they will constantly loosen up, the only best fix is to replace the hose and the swivel fitting that gets damaged by the wrong hose fitting (damaged inside on the 30 deg seat of the swivel adapter)
Not sure on other brands of hose fittings but Gates swivel hose ends (MPX) are the only ones that don't have the 30 deg seat....all the regular Gates straight male pipe ends have the necessary taper
Will it work in a pinch?.....sure, but it ain't right and will damage the adapter the first time it gets cranked on
MB I was referring to is MB Tractor near Luke
   / Swivel Fittings #13
OK. I was thinking maybe Monkey Business or something. Might not have missed it too far. lol
   / Swivel Fittings #14
So now I think I understand.
I thought ALL NPTM fittings had a VERY small bevel on the end. Like 1.5mm wide while the swivel NPTF has a bevel width of more like 5mm. I have never seen a NPTM fitting, sold for hydraulic applications, with threads that go all the way to the end. I was envisioning two wide mating surfaces like JIC. I apologize for the confusion.
I knew I should've kept my mouth shut. :D
   / Swivel Fittings #15
Hey /pine, You are absolutely correct in your reply about using the wrong pipe fittings without the 30 deg chamfer.......I have seen many jobs in the past come in where some other repairman used the wrong fittings (without the chamfer) and they will constantly loosen up, the only best fix is to replace the hose and the swivel fitting that gets damaged by the wrong hose fitting (damaged inside on the 30 deg seat of the swivel adapter) Not sure on other brands of hose fittings but Gates swivel hose ends (MPX) are the only ones that don't have the 30 deg seat....all the regular Gates straight male pipe ends have the necessary taper Will it work in a pinch?.....sure, but it ain't right and will damage the adapter the first time it gets cranked on MB I was referring to is MB Tractor near Luke
I've got a number of straight and 90 swivels lying around here that I destroyed before I knew better
   / Swivel Fittings #16
NPTF MPX
Luke if you look close at the pix of a MPX you'll see there is no 30 deg chamfer inside the ID
   / Swivel Fittings
Thanks for the help guys. Turns out that the hose fitting all have the small i.d. chamfer so looking good. I saw that Tractor Supply had them and went there tonight; they had only one in the store. I'll try NAPA in the morning. I'll post pix soon.
   / Swivel Fittings #20
If you wait a few days for delivery...The average cost of a swivel fitting (usually same quality) online is about $3.50+/- (depending on size and angle)...where I think they are about $12.00+ in the bubble wrap packages at a lot of retail ag stores etc...
Personally, I mostly see the non-chamfered straight pipe ends on fittings like reducing bushings etc...
PALLET OF WALL PACKS (A51244)
PALLET OF WALL...
4' DISC HARROW (A51243)
4' DISC HARROW...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
SET OF CATERPILLAR SKID STEER PALLET FORKS MAST (A51244)
SET OF CATERPILLAR...
