Switching hydraulic lines
   / Switching hydraulic lines #1
I am in the process of installing a snow blade on the front of my Kubota L3000. It will be attached under the front and I will be removing the bucket. It is a blade off of a pickup. What I want to do is to switch/reroute the hydraulics from the bucket lines so I can use the joystick to raise and lower the blade and to turn it left and right. What I am looking for is a valve to shift the hydraulics from the bucket lines to the plow blade lines. It will need to switch 4 lines. I would like to do this with one valve/handle. Are they out there? I've seen them for 2 lines but not 4.
   / Switching hydraulic lines #2
   / Switching hydraulic lines #3
If you are removing the FEL, I don't understand why you would need 4 lines. The FEL lift line lifts the blade and the curl lines angle it.....
If you are only removing the bucket, then you need a 3rd valve to control the angle, or use the curl valve by fixing the curl in one spot with clamps of some type.(plow lift chain back to FEL structure) I like the 3rd valve system
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XLT...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
TIRE MOUNTING AIR MACHINE (A53843)
TIRE MOUNTING AIR...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
