Mowing Switching Deck Gears
   / Switching Deck Gears #11
I think its a confusion of terms. You could put 8 blades on the spindle. Thats in its self, doesn't change the tip speed of the blades.
   / Switching Deck Gears #12
You are correct. Tip speed gives you lift and cut frequency due to RPM. Doubling the blades does the same thing without the RPM. That is all I am saying.
   / Switching Deck Gears #13
I am not saying that the RPM is increased, but if you think about the tip of the blade passing a stationary point and then count the time till it passes that point again, you are cutting that time in half by doubling the blades. Think about it.
Ummm, you will have twice as many tips go by during 1 revolution. But each tip is going to go by at the exact same speed as before. So the tip speed has not increased. You have twice as much cutting action, but not more tip speed.
2011 Ford F150 Ext. Cab Pickup Truck (A55973)
2011 Ford F150...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
HYD SPIN SPREADER (A52707)
HYD SPIN SPREADER...
2005 Hyundai 49' Dry Van (A56469)
2005 Hyundai 49'...
3650 (A47477)
3650 (A47477)
Peterbilt 377 Semi-Truck (A55315)
Peterbilt 377...
