Mowing Switching Deck Gears
   / Switching Deck Gears #1
69B4MYTYME
MANHEIM, PA
BX24
Ok, the mowing season is coming and I really fight with the cut my BX24 w/rpk60 mower gives me. 1st off I have the standard industrial tires which lays the grass down in the center of the tread and the deck doesn't lift it up even if I slow to a crawl. 2nd I've tried 4 different sets of blades high lift, mulch, standard and gator currently running gators. 3rd tried the mulching kit so rather than leaving "wind rows" I was getting "mulching clumps", removed it. So I've resorted to mowing and raising the deck 3/4" and mowing the "wind rows" a 2nd time. So on with the thought if I replaced the rpk60 bevel gears with rpk54 bevel gears I should get a faster Blade Tip Speed BTS increasing lift from the blades. Anyone know if this can be done and if it helped.
   / Switching Deck Gears #2
I have had the same problem with a Simplicity mower. The last thing I did helped a lot. I got mulching blades from Gator. They have a big wing on the back of the blade and really do help lift the grass. Cutting when the grass is dry also helps.
I agree with your blade speed question. I have used Simplicity mowers for years and always loved the cut. But when I bought this machine a while back the cut stunk. They had slowed the blades down. I think this was done for safety. I believe all blades must stop in a given time. I had also considered changing the main pulley to speed up the blades I was going to go to a smaller one but the change was gonna be a pain because of the way it was attached to the shaft.
   / Switching Deck Gears #3
I switched to the Meg-Mo blades on my out-front 72" mower. These blades are a 24" metal disc with four small swing-blades attached. You get twice the tip speed and lift and the cuttings are super fine. They do a great job.
   / Switching Deck Gears #4
what engine rpm are you running at for mowing?
   / Switching Deck Gears #5
Increase the height from front-to-back of the deck to the maximum.
I'm running just over 1/2" difference . Makes the front of the MMM
deck throw better. Keep the revs over 3200 if you're not getting enough
cuttings spread.
   / Switching Deck Gears #7
Twice the blades.......half the blank space between tips = twice the tip speed
   / Switching Deck Gears #8
Um yeah, it may cut better, but I don't see how the blades turn any faster unless you swapped pulleys.
   / Switching Deck Gears #9
Tip speed is a function of the RPM of the blade. You are getting twice the cutting action, but still at the original tip speed.
Take Care,
Doug in SW IA
   / Switching Deck Gears #10
I am not saying that the RPM is increased, but if you think about the tip of the blade passing a stationary point and then count the time till it passes that point again, you are cutting that time in half by doubling the blades. Think about it.
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52128)
NEW 2024 LOAD...
2012 Ram 1500 LARAM LONG (A50323)
2012 Ram 1500...
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
2015 FREIGHTLINER CASCADIA DAYCAB (A52472)
2015 FREIGHTLINER...
