switched tires to 'wide' - now leak?
   / switched tires to 'wide' - now leak? #1
wango tango
Peoria IL
hey all, i reversed my front tires so that the tractor has a wider stance and is more stable. since then i've noticed a leak thats slowly getting worse. the leak looks to be coming from the left front axle area. it seems to be the center housing seal area.
was reversing the wheels a bad idea? i'm assuming i need to change all the parts in that area, not just the seal? any advice would be appreciated.
   / switched tires to 'wide' - now leak? #3
Probably not related, the seal just decided it was time to go...
David from jax
   / switched tires to 'wide' - now leak? #4
Hmm...puts a lot of extra strain on the axle. If you have a front end loader on then I would bet the leak is related.
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
2022 KUBOTA MX5400 HST TRACTOR (A54607)
2022 KUBOTA MX5400...
2006 STERLING L7500 DUMP TRUCK (A51406)
2006 STERLING...
