switched tires to 'wide' - now leak?
   / switched tires to 'wide' - now leak? #1
wango tango
Peoria IL
hey all, i reversed my front tires so that the tractor has a wider stance and is more stable. since then i've noticed a leak thats slowly getting worse. the leak looks to be coming from the left front axle area. it seems to be the center housing seal area.
was reversing the wheels a bad idea? i'm assuming i need to change all the parts in that area, not just the seal? any advice would be appreciated.
   / switched tires to 'wide' - now leak? #3
Probably not related, the seal just decided it was time to go...
David from jax
   / switched tires to 'wide' - now leak? #4
Hmm...puts a lot of extra strain on the axle. If you have a front end loader on then I would bet the leak is related.
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2016 FORD F550 SUPER DUTY SERVICE TRUCK (A51406)
2016 FORD F550...
2006 FORD F-150 PICKUP (A54313)
2006 FORD F-150...
Bale Spear - Fits John Deere 300/400/500 Series Carrier (A55218)
Bale Spear - Fits...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
1985 Ford Ltl9000 Tender Truck (A55301)
1985 Ford Ltl9000...
