swisher zt2350 purchase
   / swisher zt2350 purchase #1
headachers
indiana
KIOTI DK35
just arrived yesterday, online purchase from rural king . arrived in crate 0 hrs. on hour meter ,very clean plastic covered. added gas started first crank ,ride is rough but the yards i mow are rough . the speed of this mower (6 mph) seems plenty for what i mow considering the rough yards. i will post results as i continue using the mower if there is any interest . thanks, jim
   / swisher zt2350 purchase #2
I will be very interested to know how you get along with your Swisher mower. I have looked at them and am still considering one. I have looked at the 60 inch model.
Don Williams a.k.a. librarian
It's been raining here last two days , when it dries out a little i will take mower to 2 ac. camp area that is fairly smooth & report how it does there, so far i am pleased with how little gas it is using . thanks, jim
   / swisher zt2350 purchase #5
Go mow some wet grass and let us know how it handles it.... I'm curious! That is the mark of a good ZTR if it can handle wet grass without clumping.
   / swisher zt2350 purchase #6
They don't use much gas sitting in the barn : )
   / swisher zt2350 purchase #7
Jim,
I was just wondering how you are getting along with your Swisher. You had said you would post after you had used it. Did your grass stop growing (wink wink)?
Don Williams a.k.a. Librarian
   / swisher zt2350 purchase #8
I've had my swisher 2350 for about a month now. It mows great wet or not.I mow around my pond right through puddles no clumping.My JD 430 with 60"deck
takes 2 hours to mow 1.5 acres,..ZTR 1 hour! Wow all for under 3K.As for the 60
inch swisher it was $900 more I couldn't justify that. So I got a rotary rake and a sweeper with it . I think she will do.
   / swisher zt2350 purchase #9
Thanks for the update. I am still doing all the research I can abouit ztr mowers. I have just under 2 acres to mow and have looked at a number of ztrs both residential and commercial. I still haven't made up my mind.
sorry for not getting back sooner,very busy mowing . had a charging problem with the swisher after about 3 days of use the battery waas dead , charge it go another 3 days, dead battery. i mow about 3 ac. per wk so i couldn't be down very long ,having the mower on 10 days i called main store in matoon ,il.swapped it out, back to mowing again about 6 hrs on mower now ,let a little air out of tires seems to ride a little better . thanks, jim
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
2001 Ford F150 (A50121)
2001 Ford F150...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A55218)
2021 NEW HOLLAND...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
