Swisher Trail Cutter Maintenance
   / Swisher Trail Cutter Maintenance #1
kellyann
West Luther Ontario
Arctic Cat ATV and attachments
While I was checking out my trail cutter today, in advance of mowing the tall grass at back of the field, I noticed it was very rusty underneath. The body of the mower as well as the blades are covered in rust (possibly from the wet grass mowed last fall). What is the best way to prep the mower for winter storage and, how do I clean up the rust I have now?
It is pretty hard to get under the trail cutter also, short of jacking it up? I'm a 56 year old farm gal so no great feats of strength are likely. LOL Thanks
   / Swisher Trail Cutter Maintenance #2
WELCOME TO TBN !!!!!!!!!!!!!!!! :thumbsup:
   / Swisher Trail Cutter Maintenance #3
:welcome:
from Texas
   / Swisher Trail Cutter Maintenance #4
You might try coating the underside and any moveable parts with Fluid Film. Lots of folks seem to love the stuff. I found it at a local NAPA.
   / Swisher Trail Cutter Maintenance #5
flat head screw driver, paint scrapper, wire brush, and an air compressor, is what i use to clean out all the old gunk (weeds, mud etc...) from underneath the deck.
drain the fuel, so carb doesn't take a hit with fuel turning into varnish on ya.
floor jack, bottle jack, cherry picker...
thinking about it a cherry picker, might be better choice.
googled "cherry picker" and grabbed first image that showed up..
it would allow you to lift the deck up higher. guessing a cheap cherry picker, would be more than adequate to lift the deck up. with the boom fully extended out. working on concrete or paved driveway, would be a big thing, so you can move everything around easily.
though you would most likely want to drain the oil out of the engine first, so oil doesn't go all over the place as you tip the deck up on its side.
   / Swisher Trail Cutter Maintenance #6
Do you have a winch on your atv?
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
2006 Hummer H3 4x4 SUV (A51694)
2006 Hummer H3 4x4...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Ford 18in. Stock Rims (A53117)
Ford 18in. Stock...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
9202 (A50322)
9202 (A50322)
