Swinger Titan 160-B Hydostatic pump
   / Swinger Titan 160-B Hydostatic pump #1
Michael Kelly
Tillamook, Oregon
Swinger Titan 160-b
This is a first time post for me on this forum. Thanks for bearing up with my description.
I have a Titan 160-B Swinger that has been running just great. But this last winter when scooping out the horse manure, the whole hydraulic system stopped working. The Perkins diesel engine continued to operate just fine. Finally tore the pump off this summer and discovered that the splines on the pump shaft that fits into the engine flywheel were stripped off. Not sure how that happened. But..
I am wondering where to purchase another hydraulic pump shaft. Or worst case to have to buy the whole pump.
Any ideas from owners, mehcanics or parts dealers. Thanks
   / Swinger Titan 160-B Hydostatic pump #2
Try just replacing the spline coupling in the flywheel. They are made of softer metal than the pump shaft.. On re-assembly, re-alignment is important. The Swinger 100 I have with a Kubota uses a flex plate coupling. Another I have with a ford 2000cc uses a double roller chain coupling but needs replacement every 5 years.
   / Swinger Titan 160-B Hydostatic pump #3
Mike
Any model code or part numbers on the pump? If yes what are they? Maybe possible to get just the shaft.
If the splines are in a non-lubricated environment they can wear called fretting. Applying a good moly based grease during assembly can help reduce this.
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2018 Ford Explorer SUV (A55758)
2018 Ford Explorer...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A54607)
2006 KENWORTH T800...
10 FT Poly Bunk Feeder (A55218)
10 FT Poly Bunk...
