Sweet corn "isolation required"
/ Sweet corn "isolation required" #21
How much does cross pollination matter if you're not raising seed? I've always staggered my plantings anyways, as I can only eat so much corn.
4000 seeds is a LOT of corn! 300 dozen ears even if you only get one per stalk. Do you sell, give it away, or freeze the surplus?
Cross pollination is irrelevant if you are not raising seed. The plant will produce true to its genetics, and pollen has no effect. Things are much different for second generation. Many garden plants are promiscuous cross-pollinators. Broccoli, turnips, kale, cauliflower, canola, etc. are all bred from mustard, and will cheerfully breed with each other. Squash, pumpkins, cucumbers, and melons will have *** with each other and the next generation seeds can be pretty interesting. Corn (maize) is a notorious vegetable ****, since the tassels distribute pollen on the breezes. If you want to save corn seed, half a mile of isolation will probably work, unless it's windy where you live.
/ Sweet corn "isolation required" #22
Sweet corn will cross pollinate with "field" type corn;I found out the hard way.Stagger your plantings dates.Makes for poor sweet corn if it crosses.
That must be why I've never had a problem, my plantings are about 2 weeks apart, and/or I'm planting early and late corn.
I also have no reason to plant field corn, and there are no real farms nearby.
That's what I thought. It's a lot easier for me to just buy seed every couple of years, rather than try to save it.
OK...but am getting confused.....I've read "supersweet", "field", "seed",etc.
So for this year's crop - what I want to pick and eat/donate....if I have 4 different varieties of "sweet corn" growing in close proximity.....will the corn be just fine? I don't care if the seeds are no good for next year....just will what I pick this year be what the plant would normally produce if "isolated"? Or am I going to get some nasty inedible trash corn because different hybrids of sweet corn cross-pollinated?
While I'm asking dumb questions........
Germination 6-12 days, maturation 74 days.... does that 74 days include the germination time or in addition? Should I expect to be picking corn 74 days from the time the seed goes in the ground or 74 days from when it sprouts? I know that "74 days" isn't exact either - weather, soil, etc are variables. But plan would be to have some variation in the different types so they shouldn't be all ready to pick at once. Staggering planting times a better way & will do some of that too, but different varieties range from 70-94 days maturation. Would I include the the additional ~9 days germination time to have an appx time to harvest from when I plant?
I know from how my pumpkins were ready way early last year that I need to put them in the ground early July this year so kind of backwards planning from that to have corn done prior to that & enough break in between to add some organic matter, kill bugs, or process corn.
/ Sweet corn "isolation required" #24
Germination time depends on soil temperature more than anything except perhaps moisture. Putting down black plastic either before or after planting can help if you want to plant a little earlier. That's another reason why I start my corn inside, but I only grow a couple of 20 foot rows per planting. (I also share it with my pigs, turkeys, chickens... the only one who doesn't get any is my dog.)
Maturation date is rather fuzzy, but on corn is roughly from the time that you plant it. If you're planting it by hand you also can get a head start by presoaking the seed for 24 hours in wet paper towels. I also have put the seeds in furrows, then soaked it down good before covering them up.
/ Sweet corn "isolation required" #25
If you want heat, use clear plastic. Black plastic acts as a black body radiator and actually refrigerates the ground at night.
/ Sweet corn "isolation required" #26
Super sweet corn can only be pollinated by other super sweet corn. Regular sweet corn is not a problem with cross pollination
/ Sweet corn "isolation required" #27
If anyone in our neck of the woods, has any of that bad cross pollinated corn, just send it our way and we'll test it. :stirthepot:
/ Sweet corn "isolation required" #28
When we had corn it was never isolated. We had a "corn patch" about 40' x 80'. Always planted three types of sweet corn. Three different germination/picking dates. That way we had corn for a longer time.
It never seemed to make any difference. Each variety was easily identifiable and remained true to its type.
One year we planted a new, ultra productive corn type. About a week before picking the blackbirds came in and ate it all.
/ Sweet corn "isolation required" #29
/ Sweet corn "isolation required" #30
Raccoons are notorious sweet corn destroyers.
They will wait until the day before you plan to pick it.
Ask me how I know?
MANY times !!!
/ Sweet corn "isolation required" #31
They probably rushed it so that they could beat the raccoons and skunks. Also the crows, turkeys, squirrels...
/ Sweet corn "isolation required" #32
Your corns growing days are not calendar days.
Corn growing degree days (GDD) are calculated by subtracting the plant's lower base or threshold temperature of 50 °F (10 °C) from the average daily air temperature in °F or °C. Average daily air temperature is calculated by averaging the daily maximum and minimum air temperatures measured in any 24-hour period.
NDAWN Corn Growing Degree Days Information
If you bunch your different varieties together, planting the same seeds in a cluster of shorter rows you will get better germination then say 2 long rows of the same corn. As far as them cross pollinating it will not make a difference to the eating corn.
If you are trying to save seed from the corn that you raised it would, but most sweet corn is hybrids what you raise quite likely will not be what you planted.
If that is the intent you will need one of the "heirloom" breeds and it would need to be completely isolated.
2017 VERMEER TG7000 TUB GRINDER (A66091)
2017 VERMEER...
2018 BRADLEY MACHINE MINI VAC TRAILER (A67714)
2018 BRADLEY...
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
Generac SD135 136kVA Standby Diesel Generator (A66734)
Generac SD135...
2016 VOLVO SD115B PADFOOT ROLLER (A65056)
2016 VOLVO SD115B...
1997 KENWORTH T300 4X2 S/A CAB & CHASSIS TRUCK (A69167)
1997 KENWORTH T300...
