Sweet corn "isolation required"
/ Sweet corn "isolation required" #1
CMV
Platinum Member
NC
Kioti NX4510HST (previous LS XJ2025H, JD 500C)
Was going to do some corn & summer squash this year. Can get those in & done before time for pumpkins to go in the ground. Not a lot of corn - maybe 4000 seeds or so. The descriptions for various seeds say "isolation required" and the rows or 2 areas to plant aren't really far enough apart to prevent cross pollination. So does that mean just pick one type & go with it? Or is sweet corn sweet corn and it would only be a concern if I had other types like decorative or feed corn going too?
Was wanting a few different types - just to see what holds up to bugs and whatnot the best, what does best in my soil [orange clay], and maybe have some separation where it isn't all wanting picked at same time.
Oh - and is a horribly bad idea to do squash & corn, then follow with pumpkins in same place, same year? Kind of thinking would be a good opportunity to get the bugs that got a lot of my pumpkins last year - let the squash draw them in & concentrated in that area, then insecticide when squash/corn are done but before pumpkins get started. I get a little of a pine chip/chicken poo mix from a friend so will have some organic material to till in between them, but it isn't much. I get a pickup bed at a time, plus whatever small compost piles I have produce.
This is more hobby than anything. We about broke even on pumpkins last year (assuming we work at $0/hr). Did a little squash, but didn't sell any - that was all for us & to give away. We gave a LOT away since they did pretty well. Probably same this year....sell the pumpkins, give away squash & corn.
/ Sweet corn "isolation required" #2
Dunno, haven't read up that much on it so I'll be interested to see what others say. I have three varieties of sweet corn and was hoping to do a few rows of each next to each other.
/ Sweet corn "isolation required" #3
corn varieties should be isolated so that what you harvest is true to the seed you planted. isolation can also mean by pollination time rather then by distance.
/ Sweet corn "isolation required" #4
Winter squashes and pumpkins (for pies) do not mix good either.
/ Sweet corn "isolation required" #5
How much does cross pollination matter if you're not raising seed? I've always staggered my plantings anyways, as I can only eat so much corn.
4000 seeds is a LOT of corn! 300 dozen ears even if you only get one per stalk. Do you sell, give it away, or freeze the surplus?
/ Sweet corn "isolation required" #6
I was thinking 4K was a bit more than one person could use. I have three small packets, maybe a 100 or so in each. I may sell some to the neighbors or give some to a food bank. I don't eat much of it, but want to do something different.
/ Sweet corn "isolation required" #7
when you're growing sweet corn the seed is what you're raising.
/ Sweet corn "isolation required" #8
Disagree. Most plant it for food, even though it's the seed we eat. Planting for seed means letting the kernels dry and packaging for planting next year.
I have no idea what kind of survival rate they'll have. So 4,000 seeds minus what doesn't sprout, minus what some critter chews up as a seedling, minus what some other critter tramples, minus plants/ears bugs destroy, minus what doesn't get pollinated, etc....no idea what final yield would be from that. But since seeds come in increments of 500/1k figured 4k would be good number and could do 4 types maybe? Not a farmer by any means - just something to do with land that is otherwise idle. Also something constructive for me to do after work & on weekends so I'm not idle either :)
Our church is pretty big & supports numerous other outreach groups - plenty of them would be grateful for a bunch of corn & squash if everything grows well. Won't go to waste that's for sure. Even the leftover pumpkins we had last year - took them & fed to pigs & turkeys at a nearby farm. Had no idea turkeys ate pumpkins..... :)
/ Sweet corn "isolation required" #10
That's a good plan. Your statement "Not a lot of corn - maybe 4000 seeds or so" just seemed ironic to me. I try to start mine inside so that I don't sacrifice as much to crows, but that would be quite time consuming in the quantities which you are growing. I also like to hill my corn, for stronger root systems. By planting seedlings I can use the trencher on my Troybilt to dig a trough and bury them a bit deeper.
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2002 Crosley 14ft. T/A Flatbed Equipment Trailer (A59230)
2002 Crosley 14ft...
Caterpillar 928G Articulated Wheel Loader (A59228)
Caterpillar 928G...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-150...
2019 Dodge Charger Sedan (A59231)
2019 Dodge Charger...
159115 (A60430)
159115 (A60430)
