Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,003
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Plumbing question /forums/images/graemlins/shocked.gif /forums/images/graemlins/blush.gif
I just got done rerouting some pipes in the basement and added an additional outside faucet.
Part of what I sweated was a verticle joint.
I know that heat will draw the solder in, but I saw an awful lot of solder dripping down the side...after all, gravity IS king /forums/images/graemlins/tongue.gif
My question is, do "verticle" sweats (verticle pipe and an elbow on top) suck up solder just as easy or will that inherently be a weak joint?
I don't WANT to drain the water & redo it all as it seems to be working perfectly fine.
If on the other hand, if what I'm calling verticle solders are inherently weak, it might be worth taking apart now (after marking the angles) and putting it all back after resoldering that specific joint.
I REALLY don't want to do that though, unless there's a lot of inherent wisdom in it. I put a lot of solder there to give it plenty of opportunity to suck it up.
Oh, and I heated the opposite side of the elbow from where I put the solder. I also heated the "bend" in the elbow so by the time the heat reached the actual joints and warmed them up enough to melt the solder, I'm fairly sure that being hot enough was not an issue.
Any thoughts/wisdom?
/forums/images/graemlins/smile.gif
