Chains "sway chains" and the use of locking pins
   / "sway chains" and the use of locking pins #1
garchib
southern NH
JD 4100 HST, Craftsman YS4500
\"sway chains\" and the use of locking pins
While over at my brother's yesterday watching him hook-up his RMM to his new Kubota B7800, I noticed his sway chains / links had holes through the threaded portion that allows you to put a spring pin into the hole. This prevents the sway chain / links from loosening during use. My first thought was, I wish my JD 4100 had those holes, as I am always hopping off the tractor while mowing to tighten the sway bars. Well, wouldn't you know it, I get home and look and I DO have those holes. I go to my manual right away and it mentions them in the manual. So I went on-line to JD Parts and ordered (4) of them for ~ $ 3. This begs the question, did everyone get these with their tractor ? I am not holding the dealer responsible, as it took me over (3) years to catch this. /forums/images/graemlins/blush.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
   / "sway chains" and the use of locking pins #2
Re: \"sway chains\" and the use of locking pins
My 4010 turnbuckles came with pins to hold them in place. I looked at them and viewed them as unusable and a royal nuisance. I just tighten mine and use tension cords to keep them there. I just hook the other end of each cord on a hole in the ROPS. Mine have never loosened.
Main problem I have is getting them straight onto the loops so I can tighten them correctly. Didn't do this once, and my LX4 swung over and caused one of the lift arms to rub on a rear tire. Just didn't get it tight because it wasn't seated properly in a loop at each end of the turnbuckles.
Ralph
   / "sway chains" and the use of locking pins #3
Mine are bars with holes in them and no adjustment. There are numerous round holes and also some slotted holes to allow a little "give"
2011 Ford Transit Connect XLT Cargo Van (A50323)
2011 Ford Transit...
1997 Wells Cargo Enclosed S/A Trailer (A50324)
1997 Wells Cargo...
2013 Honda CR-Z EX Hatchback (A50324)
2013 Honda CR-Z EX...
UNUSED AGT QK20R EXCAVATOR (A51243)
UNUSED AGT QK20R...
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
