swashplate sensor problems
   / swashplate sensor problems #1
swein
Maryland
toolcat 5600
Have any of you toolcat owners had problems with the swashplate sensor a 50-20 error code. Loose power to all wheels and when restarted becomes operable until the error code comes on again. If so, what did you do about it and what did it cost? swein
   / swashplate sensor problems #2
There is no way to override the system to operate without it. It requires signal from both swashplate sensors to keep front & rear axle speeds close to same. Replacing the sensor is not difficult, more than likely it is getting access to it that is time consuming. Not sure how accessable they are on the Toolcat but in the skidloader 1 is easy to get to, the other requires taking pump mount loose and jacking it up and more times than not this is the sensor that goes bad.
   / swashplate sensor problems #3
i have a Bobcat A300 its right swash plate sensor creat a problem (swash plate not in neutral).how i replace that sensor?
   / swashplate sensor problems #4
where exactly are they located on a s650 bobcat
   / swashplate sensor problems #5
Sensors are on bottom side of hydrostat, opposite the electronic controller solenoids.
Fifth wheel multi use trailer. (A51039)
Fifth wheel multi...
1982 TANDEM AXLE CEMENT MIXING TRAILER (A50854)
1982 TANDEM AXLE...
FUEL TANK/TOOL BOX COMBO (A50854)
FUEL TANK/TOOL BOX...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2015 Isuzu NRR John Bean 700 Sewer Jetter Vacuum Truck (A49461)
2015 Isuzu NRR...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
