suzue M 2000 2 cyl diesel,hyd. lift won't raise.
   / suzue M 2000 2 cyl diesel,hyd. lift won't raise. #1
boomer05
bartlesville ok.
suzue m2000
don't know a thing about this tractor,except mitsibishi bought them out in the mid 80's.tractor runs fine and the pto works fine,but lift won't raise.any manual's for this tractor?where is the pump for hydraulic's?:anyone:
   / suzue M 2000 2 cyl diesel,hyd. lift won't raise. #2
did you receive any information
I have a suzue that has the lift arms stuck in the raised position
   / suzue M 2000 2 cyl diesel,hyd. lift won't raise. #3
Have you tried to adjust the knob under the seat. Sometimes called descent knob. Rate of descent knob.
This knob is designed to set the rate of drop, or lock the cyl for transporting implements.
What it does is to block the flow of fluid out of the 3pt cyl, or let the fluid out slowly.
So if the descent knob is full left and no debris in the orifice, then the fluid should flow back to tank.
You may have a mechanical problem.
1264 (A50490)
1264 (A50490)
2015 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2015 Great Dane...
2014 INTERNATIONAL MA025 BOX TRUCK (A53426)
2014 INTERNATIONAL...
Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
Peterbilt National...
