Surprised that there are no trailer hitches with tongue weight indicators
   / Surprised that there are no trailer hitches with tongue weight indicators #1
ZiggyD
MF 2705E
Many scales use transducers that convert the mechanical force on a sensor into an electrical signal. The measurable electrical signal is then translated into weight units and displayed. I'm surprised there aren't trailer hitch mounts that have a similar sensor that'll give a reading of the tongue weight. A rectangular sensor inserted into the structural steel of the hitch can measure compression on the bottom and expansion on the top and output the readings to a display on the tongue. Tongue weight is an important safety aspect of towing and I'm surprised none of the big manufacturers implemented something similar.
Thanks for coming to my TED Talk...
   / Surprised that there are no trailer hitches with tongue weight indicators #3
I guess you did not look to hard for one.
I've seen the mechanical ones. They're too expensive and bulky for casual towing. Still surprised that there's no electronic solution for this.
   / Surprised that there are no trailer hitches with tongue weight indicators #8
While I can see that as a good way to keep weight off the back of the tow vehicle and back onto the trailer axels.
I can also see my idiot neighbor putting weight too far back and causing instability problems, and/or loading the trailer past capacity.
   / Surprised that there are no trailer hitches with tongue weight indicators #9
Heavy Duty Jumper Cables (A55788)
Heavy Duty Jumper...
2018 FORD F-150XL CREW CAB TRUCK (A52706)
2018 FORD F-150XL...
2024 New Holland T8.410 MFWD Tractor (A55302)
2024 New Holland...
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
2009 Nissan Versa (A47477)
2009 Nissan Versa...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
