Surplus Steel around Houston
   / Surplus Steel around Houston #1
RobJ
Elite Member
Spring, TX (Houston)
Kubota L2500
I usually use SSS Steel. Happy, yes, surplus yard ok, inventory changes all the time.
Today I'm off so I went by Rose steel. HAven't been there since they moved from the I-10 location. I bought some 16ga 1" and 3/4" tubing(swear it could be 14 or 12 gauge :D). But Rose steel, parking(very little) a nightmare, mass confusion(a Monday around lunch), but prices pretty close to SSS on small square tubing. The price was more but I bought 24' instead of 20'. Looked close enough. I picked up some biq square tubing, $.50 a pound. They load on a little electric cart and take to your truck. Rose is MUCH better in looking for that little piece of steel, or whatever. Mill around, find what you need, buy a 2' piece of whatever. I think I'll be going there a little more often in the future. Massive selection of those little pieces, that's worth the extra 5 minutes to get to the place.
Rob
   / Surplus Steel around Houston #2
Rob,
Where are they located?
   / Surplus Steel around Houston #5
Hey Jester: Have you bought anything from Texas iron and metal?
I have and I will try very hard not to ever buy anything from them again!!
They tried to charge me more than new prime prices for outside surplus yard steel. I got into it with the sales guy and then the manager came out and dropped it some but it was still overpriced. Only reason I didnt just leave was one piece I wanted was 5 inch square solid by 30 inch long that I wanted for some machining projects and triple S doesnt keep solid bar around.
EDIT: Jester, You have one post, and posted the link for Tx iron . Interesting. Anyway if somebody has contact with them they could suggest that they adopt a standard per pound charge for surplus steel like 50 cents a lb that the other places charge instead of a runaround BS of " The price depends on what type of steel it is- flat, tube, beam, bar, everything is priced different and then we have our markup blah blah blah. Net result they want to charge $1.20 or 1.50 lb for rusty outside surplus when new grade A at triple S is about 80 or 90 cents a pound.
   / Surplus Steel around Houston #6
Tx iron does have a nice surplus yard with a lot of steel avail. If they get the pricing figured out I would buy from them as they are fairly convenient for me as far as location , I could go there before work.
You guys would sell a crapload of that surplus square and rectangular tubing and beam stock if it were priced right , otherwise its just gonna sit there forever and rust and then finally get sent to the smelter at 15 cents a pound.
It's a little far out for me. Might get by there one day but I'll not pay $1.20-$1.50 pound for outside stuff. Actually on the 16ga tubing and such, while the price has doubled in the past 3 years or so, it's still "reasonable" IMO for some projects. But the heavier stuff, which might be priced at the same weight..dunno for sure...gets crazy.
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2011 MACK CHU (PINNACLE) (A58214)
2011 MACK CHU...
TEST YOUR BID BUTTON! (A58375)
TEST YOUR BID...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
