Surging engine
   / Surging engine #1
Gixxer
Louisiana
Kubota L3400DT
My 23hp Kohler surges when ever it doesn't have a load on it. When I just drive from one place to another it surges, as soon as I load it by engaging the mower deck it stops. Changed fuel filter and gas cap and it still does it. Recently I bought non ethanol gas filled up the tank cut half the yard and it started surging. Ran the mower out of gas put new ethanol gas and it continues to run the same way. Anyone have an idea what could've happened?
   / Surging engine #2
Sounds like it may be gunked up in the carb, or the carb needs some fine adjustment.
Is this straight carb or fuel injected?
What is the engine on?
   / Surging engine #3
Yep,that's what I would think too.
I believe it is still surging,even under load. Alot of times,it's just not as detectable when under load or full throttle.
Greg
   / Surging engine
It's on a John Deere L130.
   / Surging engine #5
The carb is the first place to start.
If you aren't sure of yourself doing this kind of thing,it's best to let someone else do it. I noticed in the JDParts schematic,there is a fuel filter before the fuel pump. Definitely change that one,and if at all possible I'd put another one after the pump too. Two filters are better than one.:)
Greg
   / Surging engine
Well forgot to post but it must have been some trash. It fixed itself.
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 78in Dual...
TMA (A49461)
TMA (A49461)
2022 Chevrolet Tahoe FL SUV (A53424)
2022 Chevrolet...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2025 GIYI SGB20 20in Single Cylinder Stump Grapple Bucket Skid Steer Attachment (A53421)
2025 GIYI SGB20...
2001 MACK CH613 DAY CAB (A54313)
2001 MACK CH613...
