Oil & Fuel Surging and rapid loss of power
   / Surging and rapid loss of power #1
albullock001
Colmesneil, TX
Mahindra 3616
I can get the 3616 to 2000 rpms but with any load at all the rpms rapidly drop off and it may die completely. I changed the fuel filter, both air filters and cleaned out the fuel tank....all that took a day and then it started right up, got it to 2000 rpms, engaged the brush cutter and it died within 30 seconds. Disengaged the cutter, waited 5 mins and started it up again with no load, but even moving the tractor back to the barn was slow and at low rpms. Tractor is 2 years old with 121 hours. Fuel is new, less than a teaspoon of water in the old filter. Anybody got any ideas about this?
   / Surging and rapid loss of power #2
Hydro or shuttle? Was the shredder still on it when you were driving?
   / Surging and rapid loss of power #3
On those tractors to bleed the air out right there is a bleeder on the pump. Id check around the injectors also to be sure you don't have a leak there..
Is the fuel bowl filling up?
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
International 1086 Cab Tractor 2wd (A52128)
International 1086...
