Oil & Fuel Surging and rapid loss of power
   / Surging and rapid loss of power #1
albullock001
Colmesneil, TX
Mahindra 3616
I can get the 3616 to 2000 rpms but with any load at all the rpms rapidly drop off and it may die completely. I changed the fuel filter, both air filters and cleaned out the fuel tank....all that took a day and then it started right up, got it to 2000 rpms, engaged the brush cutter and it died within 30 seconds. Disengaged the cutter, waited 5 mins and started it up again with no load, but even moving the tractor back to the barn was slow and at low rpms. Tractor is 2 years old with 121 hours. Fuel is new, less than a teaspoon of water in the old filter. Anybody got any ideas about this?
   / Surging and rapid loss of power #2
Hydro or shuttle? Was the shredder still on it when you were driving?
   / Surging and rapid loss of power #3
On those tractors to bleed the air out right there is a bleeder on the pump. Id check around the injectors also to be sure you don't have a leak there..
Is the fuel bowl filling up?
2015 International DuraStar 4300 Johnston VT651 Street Sweeper Truck (A50323)
2015 International...
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
2005 Sterling Single Axle Dump (A47384)
2005 Sterling...
2014 John Deere 544K 2 Wheel Loader (A47384)
2014 John Deere...
2019 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
