surge protection
/ surge protection #1
Tdog
Platinum Member
SE Louisiana
BX22
Does anyone have any experience with a whole house surge protector? I'm aware that they still recommend end-point surge protection, too, I just wonder if a unit at the electrical panel is justified?
I just read the post of a power surge being blamed for a blown circuit board in a garage door opener, - - - - & it is somehting I've been curious about. I've had several blown appliances in the 9-10 years I've lived in the sticks - - AC, remote phones, etc.
/ surge protection #2
I always thought Hydro-Quebec was the worst for spikes/brownouts, but I haven't had any problems yet. I don't have any experience with circuit panel protectors, but you'd better believe that I have a UPS on my PC and modem line. Out of curiousity, what is the main source of your power (hydro, nuclear)?
/ surge protection #3
Based on what I've seen over the years, bigger surge protectors seem to have a slower clamping speed. Slower clamping speeds lead to more damage to electrical equipment.
There are some fairly good small task designed units available, but the cost of surge protection is often higher than replacement of an appliance.
Where you're protecting things like computers, nothing beats a good UPS.
Before you look at any surge protection equipment, it might be a good idea to monitor your voltage over a period of time. Very often it turns out damage to equipment is caused by old poorly maintained utility connections that have corroded.
/ surge protection #4
i work in the electronic field, and have done a lot of testing protectors of all kinds..and from what i have found, you do not always get what you pay for..the state police in arkansas has a state wide microwave communications system, they just paid mega bucks to have a company redo the grounding and protection on a lot of their sites...and they still get damaged..but of course they have a 300 ft tower standing there that the lightning sure likes..in our offices, i installed some military surplus building protectors, plus i use a lot of the power strips from wally world that have protection build in, and we have had minor damage ..at home i installed protectors from panamax on my satellite/tv equipment, in 96, and haven't had any damage since..i had lost the tv a couple times before that. the main thing is you can't put to much protection on the line..but start with the individual protectors...they may solve all of your problems. some even give warranties on the equipment they protect.
heehaw
/ surge protection
Thanks, guys. I have an APC UPS for my computer, but my individual surge protection devices for stereo, satellite, microwave, etc. are 8+ years old. Some had indicator lights that no longer light up & I should replace.
Guess it's time I got started.
/ surge protection #6
i'd probably replace them if there was a lot of lightning storms every year in that area. for the price, i don't think you can beat the panamax protectors...in fact, i don't think you can beat them by spending 10X what they cost. they work very well.
heehaw
/ surge protection #7
My home was hit twice, one a direct hit and the other hit the ground between homes and knocked out 4 homes. Since then I installed a whole house surge protector and end of point surge protection on everything. Since then I never have had a hit - go figure.
PJ
/ surge protection #8
I wouldn't be too concerned because the lights quit working after 8 years, they are usually just NE-2 neons, and you got great life from those bulbs.
Before I'd replace surge protectors with new ones, I'd research to find out how the proposed new units stack up against the ones you have.
/ surge protection #9
Ever built your own? <A target="_blank" HREF=http://www.alliedelec.com/catalog/pf.asp?FN=871.pdf>http://www.alliedelec.com/catalog/pf.asp?FN=871.pdf</A>
/ surge protection #10
yep, used MOV's for years, still do some, switched to SAS's, and about everything else on the market...have had the power cords blown to itty bitty bits, and the equipment work fine after installing a new cord....damage due to lightning has dropped significantly in the last 10 years...i think its due to the quality/speed of the protectors..
MOV= metal oxide resistor
SAS= silicon avalanche suppressor
i "think" i have those names right..??
heehaw
/ surge protection #11
i looked at walmart yesterday, they have protectors for $10 that have a 3 year protection plan, then if you pay more you get a longer protection plan..up to lifetime??
heehaw
x (A68191)
x (A68191)
2005 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2005 FORD F150...
2021 CATERPILLAR 420XE HRC BACKHOE (A65053)
2021 CATERPILLAR...
2015 RAM 1500 4 X 4 CREW CAB PICK UP TRUCK (A59914)
2015 RAM 1500 4 X...
2012 RAM 4500 (INOPERABLE) (A67714)
2012 RAM 4500...
PORTA POTTY (A68842)
