Surefire flashlights
   / Surefire flashlights #21
GaryM said:
I've been a member there too for a while. I don't post much, but lots of information to be gained by reading the posts. Just like here!
I joined CPF in Aug 2001. They are a fine bunch of people just as the people at TBN. I was not active for a few years mostly because of a long treatment for an illness that knocked me down. Now that is over and when I started back, I am amazed that so many new ideas and the shear number of new products that are available.
I was member 641 and now there are 30k+ on the forum. How time flies when having a good time.
JB4310.
I gave your question much thought. I would want a 3D Mag with at least one high power LED. I would prefer it to have 3 LED's. "D" cells are readily available. 3D would have a long runtime and the Mag body is rugged. The LED cannot be damaged by a drop and has a long lifespan before dimming.
   / Surefire flashlights #22
$1.75 a battery!:eek: Thanks to both you guys. I keep a Streamlight Scorpion in a belt pouch for emergences, partly because of the price of CR123 batteries. Only used it after a tornado. $5 for a battery is nuts. My wifes cousin use to work at walmart. He said Walmart pays 25 cents for a package of 4 alkaline batteries, then mark them up to $4. He always buys them at some place like Dollar General.
$1.75, man I love TBN:D
   / Surefire flashlights #23
As there is some interest in saving some money on the CR123A batteries, I thought all of you might like some links to good prices from trusted dealers.
Battery Junction
The Titanium are considered to be on par with the Surefire brand. $1.00 each.
Greg at Brightguy is the same price as Surefire but he is a very trusted dealer.
I'll update as I remember more sites.
BTW, a new rechargeable battery is on the market. Sanyo has come out with the Eneloop. It is a NiMH LSD (low self discharge). It only looses a small amount of charge when idle. Rayovac, Duracell and Kodak have come out with similar units but the Sanyo has tested as the best.
   / Surefire flashlights #24
I have 3 or 4 Surefire G2 Nitrolin that can be found for $35 just about anywhere. I have been very pleased. A one hour runtime doesn't sound like much, but you get one hour of consistent bright light. I purchased 24 Surefire batteries two years ago and have used maybe 8 of them, plus the ones in the flashlights. A good flashlight that always works and provides good light is indispensable. Again, one hour is a long time.
I also have a Surefire 6p which is aluminum and puts out the same light as the G2's (65 lumins). I like it a bit better but for all practical purposes it does the same job and costs at least 50% more.
   / Surefire flashlights #25
The G2 is a great value for the $. I bought a G2 shortly after they came out. They really help in cold weather. The Nitrolin does not conduct the cold to the hand.
Here are my 6P's and a G2.
The Silver one is my Wife's.
   / Surefire flashlights #26
Battery Junction
Just adding that I've dealt with both of these companies with no problems and been very satisfied.
   / Surefire flashlights #27
I saw the Sanyo rechargeable at Costco and was wondering about them. The last time I tried rechargeables years ago the technology was not very good.
I have been thinking about getting one of the Fenix flashlights only because it reads like they are more bang for the buck? It is amazing that flashlights can be so small and be so bright.
What exactly do I give up getting one that runs on aa's versus the cr123a's in a situation where it sits around and is only used occasionally?
   / Surefire flashlights #28
Most of the Pentagon brand will run on AA's as well. I have a few of these as well as Surefire and only difference is run time.
brad
   / Surefire flashlights #29
I bought 30 (yes, thirty) Eternalights in various configurations in the fall of 1999. Sold a few to friends, kept most for family, assigned one to each vehicle, and a few other important places. They throw an adequate beam for walking in the woods. Maybe 25' or so of bright useable light, 60' or so of general illumination, and they can be seen for over a mile. Chip on them allows a setting that will flash for 700 hours. Yes...seven hundred. On 3 AA batteries. Full power on all 4 leds will still get you over 100 hours. They also perform a battery strength test (1 to 4, 4 being full) in one mode. In 2005 I decided to replace all the batteries in the ones that are rarely or never used. Most of the batteries tested 3; I replaced them anyway (most had Duracell alkalines, some had lithiums). Those that get used fairly often tested 1 or 2. NONE had burned out batteries. None had failed. They do not have the small area brilliance of some newer leds I had seen, but I have yet to see a light for even close to the price that impressed me as much. Now over 7 years old, and they work like new.
Technology Associates: eternaLight LED Flashlights
   / Surefire flashlights #30
I don't see much mention of Eternalights anymore. I have one with the clear blue case and I run lithiums in it. The only problem I had with mine is, the touch pad peeled off. I just superglued it back on and it's good to go.
It's the ErgoXRay model.
Venetian Bronze Aluminum Mailbox Post (A54865)
Venetian Bronze...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
FRAME ONLY FRONT DISCHARGE CONCRETE TRUCK (A54313)
FRAME ONLY FRONT...
2009 Pierce 105ft. Quint Ladder T/A Fire Truck (A55788)
2009 Pierce 105ft...
2025 Swict 66in Bucket Skid Steer Attachment (A55787)
2025 Swict 66in...
