Supersteer and FEL work
/ Supersteer and FEL work #1
tpaulson
South Dakota
2001 New Holland TC45D, 1953 JD 40 crawler, 1949 JD A, 1993 Lahman skidsteer
I have a NH TC45D with 17la loader and supersteer. I really like the supersteer for tractor maneuverability, but for loader work it is a real pain. I dislike the fact that when you start to turn your wheels the bucket moves 8" in the opposite direction. It makes it a little hard to do precise loader work. Maybe I am just spoiled with the control my skidsteer gives me.
Is there a way to disable supersteer temporarily when doing loader work?
/ Supersteer and FEL work #2
I have the exact same setup. It just takes some getting used to. I look at like backing a trailer, the more you do it, the better it gets. I have over 150 hours on my old 40D w/ SS and my new 45D. Not an issue now....
I know of no way to disable.
/ Supersteer and FEL work #3
Howdy!
The geometry of SS doesn't allow for any way to disable what you're experiencing. In fact, if you think about it, there's no way around it:
When you're at a stop or a real slow crawl, turning the wheel allows the entire axle to pivot a bit. However, since the wheels aren't really turning over, the motion imparted by the steering mechanism means the axle must pivot, and as a result, the chassis must move in the opposite direction. Since the FEL is hooked on to the chassis, it shifts accordingly.
The first time I hooked up my loader, this caught me by surprise. But with some time in the seat, I have found it to be quite handy for precision movements. You don't have to have any forward or reverse motion to shift the bucket. Depending on the situation, that can be invaluable.
Best Regards,
Jay
2014 GMC Acadia AWD SUV (A61574)
2014 GMC Acadia...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2007 Grove RT530E-2 4x4 30 Ton Rough Terrain Crane (A61572)
2007 Grove...
Case skid steer wheels and tires (A63689)
Case skid steer...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
